Adding 285/55/20 tires, any thoughts?
LOWRMPG
Debating putting 285/55/20's on my 2025 Limited, anyone know of any issues with this setup as far as rubbing goes?
That puts you in a E rated tire more than likely. Unless you tow I would suggest staying away from them…mpg & ride quality are the biggest issues. I went with 305/55/20 with zero offset wheels.
Not E-rated, you can get SL Toyo Open Countrys in that size. I'm using the factory rim, so I don't have the beni of offset changes.
