Add Trailer Surround Camera kit (p/n 68527709AC) to my '22 RAM Limited ?
Dave314
I have a '22 Limited with surround camera and options on the UC5 for "Trailer Surround" and AUX2 selections. There are NOT any camera connectors on the bumper.
Can I add Trailer Surround Camera kit (P/N 68527709AC) ? Does the kit include the truck-side connector and wiring harness? Does the connector harness plug into the truck harness or does it need to be spliced in?
Build sheet details are below. Thanks!
Equipment Listing
VIN 1C6SRFHT4NN116027
Vehicle Description 2022 RAM 1500 LIMITED CREW CAB 4X4
CUSTOMER PREFERRED PACKAGE 2TM
CUSTOMER PREFERRED PACKAGE 25M
LIMITED LEVEL 1 EQUIPMENT GROUP
UCONNECT 5 NAV W 12.0" DISPLAY (USA)
12.0" TOUCHSCREEN DISPLAY
DIGITAL REARVIEW MIRROR
SURROUND VIEW CAMERA SYSTEM
CLASS IV RECEIVER HITCH
7 PIN WIRING HARNESS
TRAILER BRAKE CONTROL
HEAVY DUTY ENGINE COOLING
MONOTONE PAINT
220 AMP ALTERNATOR
730 AMP MAINTENANCE FREE BATTERY
BRAKE ASSIST
RAIN BRAKE SUPPORT
READY ALERT BRAKING
ELECTRONIC STABILITY CONTROL
HILL START ASSIST
TRACTION CONTROL
ELECTRONIC ROLL MITIGATION
TRAILER SWAY DAMPING
ANTI-LOCK 4-WHEEL DISC BRAKES
2ND ROW IN FLOOR STORAGE BINS
UNDER SEAT LIGHTING
KEY FOB - DARK CHROME
FRONT HEIGHT ADJUST SHOULDER BELTS
SUPPLEMENTAL SIDE AIR BAGS
CHILD SEAT ANCHOR SYSTEM-LATCH READY
ADVANCED MULTISTAGE FRONT AIR BAGS
SUPPLEMENTAL FRT SEAT SIDE AIR BAGS
CARPET FLOOR COVERING
CARGO TIE DOWN LOOPS
BRIGHT FRT & RR DOOR SILL SCUFF PADS
STANDARD EQUIPMENT
LUXURY FRONT & REAR FLOOR MATS
DRIVER/PSNGR ASSIST HANDLES, WRAPPED
LUXURY DOOR TRIM PANEL
REAR UNDERSEAT COMPARTMENT STORAGE
PREMIUM OVERHEAD CONSOLE
FOAM BOTTLE INSERT (DOOR TRIM PNL)
ROTARY SHIFTER-BLCK W SLVR STRIPE
ELECTRONIC RANGE SELECT
ELEC SHIFT ON DEMAND TRANSFER CASE
215MM FRONT AXLE
3.21 REAR AXLE RATIO
235MM REAR AXLE
CONVENTIONAL DIFFERENTIAL REAR AXLE
TINTED GLASS WINDOWS
ACOUSTIC FRONT DOOR GLASS
DEEP TINT SUNSCREEN GLASS
REAR WINDOW DEFROSTER
REAR POWER SLIDING WINDOW
SUN VISORS W/ILLUM VANITY MIRRORS
CHROME PREMIUM POWER MIRRORS
2-DOOR PASSIVE ENTRY, FRT DOOR LOCKS
REMOTE KEYLESS ENTRY
SENTRY KEY THEFT DETERRENT SYSTEM
PUSHBUTTON START
AIR COND ATC W/DUAL ZONE CONTROL
DASH LINER INSULATION
CLUSTER 7.0" TFT COLOR DISPLAY
120 MPH PRIMARY SPEEDOMETER
VAR INTERMITTENT WINDSHIELD WIPERS
RAIN SENSITIVE WINDSHIELD WIPERS
DUAL NOTE ELECTRIC HORNS
12V AUXILIARY POWER OUTLET
115V AUXILIARY REAR POWER OUTLET
LOCKING GLOVE BOX
REMOTE TAILGATE RELEASE
115V AUXILIARY POWER OUTLET
POWER ACCESSORY DELAY
N95+BIO HVAC CABIN FILTER
SPEED SENSITIVE POWER LOCKS
PWR FRONT WINDOWS, 1-TOUCH,UP & DOWN
INSTR CLUSTER THEME 4 - LIMITED
ILLUMINATED ENTRY
TIRE FILL ALERT
FRONT PASSENGER SEAT BELT ALERT
LED TAILLAMPS
VEHICLE INFORMATION CENTER
GLOVE BOX LAMP
IP LED AMBIENT LIGHT PIPE
OVERHEAD CUPHOLDER LAMP
FRONT DOOR ACCENT LIGHTING
REAR DOOR ACCENT LIGHTING
LED FOOTWELL LIGHTING
RADIO/DRV SEAT/MIRRORS/PEDALS MEMORY
HEADLAMP OFF TIME DELAY
OVERHEAD LED LAMPS
AUTOMATIC HEADLAMPS
AUTO HIGH BEAM HEADLAMP CONTROL
DAYTIME RUNNING HEADLAMPS, LOW BEAM
BI-FUNCTION LED PROJECTOR HEADLAMPS
FRONT LED FOG LAMPS
REAR LICENSE PLATE W/LAMP BRACKET
PICK-UP BOX LIGHTING
SECURITY ALARM
FULL SPEED FWD COLLISION WARN PLUS
ACTIVE GRILLE SHUTTERS
"RAM" DOOR BADGES
CHROME HEADLAMP BEZELS
GRILLE-SURR 5 CHROME TEXTURE 6 CHRME
RAM'S HEAD BADGE
FRONT WHEEL WELL LINERS
MOPAR CHROME BODYSIDE MOLDING
BRIGHT DAY LIGHT OPENING MOLDINGS
BODY COLOR/CHROME DOOR HANDLES
ACCENT FENDER FLARES
POWER RUNNING BOARDS
"1500" BADGE
4X4 BADGE
LIMITED BADGE
DAMPENED TAILGATE
REAR WHEELHOUSE LINERS
FIXED FRONT AIR DAMS
ACTIVE FRONT AIR DAMS
"RAM" GRILLE BADGE - CHROME
26 GALLON FUEL TANK
DIAMOND BLACK CRYSTAL P/C
STEERING WHEEL MOUNTED AUDIO CTRLS
ACCENT COLOR SHARK FIN ANTENNA
WIRELESS CHARGING PAD
MEDIA HUB-2 USB, FULL FUNCT, AUX
AUDIO JACK INPUT FOR MOBILE DEVICES
REMOTE USB PORT
MEDIA HUB-2 USBS (BOTH CHARGE-ONLY)
REMOTE USB PORT - CHARGE ONLY
ELECTRIC POWER STEERING
WOOD/LEATHER WRAPPED STEERING WHEEL
AIR SUSPENSION, 4-CORNER
FRONT HEAVY DUTY SHOCK ABSORBERS
REAR HEAVY DUTY SHOCK ABSORBERS
FRONT STABILIZER BAR
REAR STABILIZER BAR
TILT/TELESCOPE STEERING COLUMN
TIRE CARRIER WINCH
FULL SIZE TEMPORARY USE SPARE TIRE
275/55R20 BSW ALL SEASON TIRES
CENTER HUB
20X9.0 POLISHED WHEELS WITH INSERTS
18" FULL SIZE STEEL SPARE WHEEL
POWER ADJUSTABLE PEDALS W/MEMORY
BLIND SPOT AND CROSS PATH DETECTION
REMOTE START SYSTEM
TIP START
PICKUP BOX
OCCUPANT CLASSIFICATION SYSTEM
COAT HOOKS
ELECTRIC PARK BRAKE
FRONT/REAR CLIMATE CONTROL OUTLETS
TIRE PRESSURE MONITORING DISPLAY
REAR SEAT HEAT DUCTS
TOW HOOKS - CHROME
400W INVERTER
PARKSENSE FR/RR PARK ASSIST W/STOP
LOCKING TAILGATE
CAPLESS FUEL FILL
ENGLISH/USA LANGUAGE
MOPAR SPRAY IN BEDLINER
ELECTRONIC SHIFT
REAR BUMPER MODULE
FRONT BUMPER MODULE
GRILLE MODULE
HEADLAMP PARTS MODULE
DOOR TRIM PANEL MODULE
GLASS MODULE
STEERING COLUMN COVER PARTS MODULE
CENTER CONSOLE PARTS MODULE
FRONT FASCIAS PARTS MODULE
HEADLINER PARTS MODULE
SEAT PARTS MODULE
INSTRUMENT PANEL PARTS MODULE
DOOR PARTS MODULE
FRONT END PARTS MODULE
TIRE & WHEEL PARTS MODULE
FRONT SUSPENSION DAMPER PARTS MODULE
REAR SUSPENSION DAMPER PARTS MODULE
BUILD TO U.S. MKT. SPECIFICATIONS
GVW RATING - 7100#
U.S. DEALER RETAIL
ZONE 42-DETROIT
CREW CAB
FOUR WHEEL DRIVE (4WD)/(4X4)
2022 VEHICLE SPECIFICATIONS
PRICE CLASS M
5 FT. CARGO BOX
VEHICLE ORDER TRACKING
U.S. SPECIFICATIONS LABEL
OHIO SHIP TO STATE CODE
OHIO SOLD TO STATE CODE
PREM LEATHER TRIMMED BUCKET SEATS
BLACK
BODY COLOR BUMPER GROUP
ADVANCED BRAKE ASSIST
BUCKET SEATS
VENTILATED REAR SEATS
VENTILATED FRONT SEATS
RR 60/40 FOLDING SPLIT RECLINE SEAT
4 WAY FRONT HEADRESTS
SUPP. SIDE CURTAIN FRT/RR AIR BAGS
HEATED FRONT SEATS
FULL LENGTH PREMIUM FLOOR CONSOLE
OPTIONAL EQUIPMENT
THREE REAR SEAT HEAD RESTRAINTS
FRONT SEAT BACK MAP POCKETS
8-SPD AUTO 8HP75 TRANS
5.7L V8 HEMI MDS VVT ENGINE
AUTO DIM EXTERIOR DRIVER MIRROR
DUAL-PANE PANORAMIC SUNROOF
GPS NAVIGATION
GPS ANTENNA INPUT
ACTIVE NOISE CONTROL SYSTEM
POWER 4-WAY DRIVER LUMBAR ADJUST
HEATED SECOND ROW SEATS
POWER 4-WAY PASSENGER LUMBAR ADJUST
POWER 8-WAY DRIVER/PASSENGER SEATS
TAILGATE AJAR WARNING LAMP
LANE KEEP ASSIST
HEAD UP DISPLAY
DOME DUAL LED READING LAMP
LED DOME/READING LAMP
EXT. MIRRORS W/SUPPLEMENTAL SIGNALS
EXTERIOR MIRRORS COURTESY LAMPS
EXTERIOR MIRRORS W/MEMORY
CHROME EXTERIOR MIRRORS
DRIVER SEAT MEMORY
POWER-FOLDING MIRRORS
CONVEX WIDE-ANGLE EXT MIRROR INSERT
AUTO DIM EXTERIOR PASSENGER MIRROR
LED CHMSL LAMP
PEDESTRIAN EMERGENCY BRAKING
BODY COLOR FRONT BUMPER
BODY COLOR REAR BUMPER W/STEP PADS
FRONT LICENSE PLATE BRACKET
ALL WHEEL/FENDER FLARES
AIR SUSPENSION DECAL
HEMI BADGE
50 STATE EMISSIONS
DUAL REAR EXHAUST W/BRIGHT TIPS
EXTERIOR MIRRORS W/HEATING ELEMENT
HEATED STEERING WHEEL
ADAPTIVE CRUISE CONTROL W/STOP & GO
ALL RADIO EQUIPPED VEHICLES
19 SPKR HARMAN KARDON PREM. SOUND
GLOBAL TELEMATICS BOX MODULE (TBM)
HD RADIO
APPLE CARPLAY
DISASSOCIATED TOUCHSCREEN DISPLAY
GOOGLE ANDROID AUTO
USB HOST FLIP
INTEGRATED CENTER STACK RADIO
CONNECTIVITY - US/CANADA
4G LTE WI-FI HOT SPOT
SIRIUSXM WITH 360L
CONNECTED TRAVEL & TRAFFIC SERVICES
ALL R1 HIGH RADIOS
BRIDGESTONE BRAND TIRES
ALL ALUMINUM WHEELS
UNIVERSAL GARAGE DOOR OPENER
PARALLEL & PERP PARK ASSIST W/STOP
INTEGRATED VOICE COMMAND W/BLUETOOTH
SIRIUSXM RADIO SERVICE
FOR DETAILS, VISIT DRIVEUCONNECT.COM
FOR MORE INFO, CALL 800-643-2112
5 ADDITIONAL GALLONS OF GAS
SPRING - LEFT REAR
SPRING - LEFT FRONT
SPRING - RIGHT REAR
SPRING - RIGHT FRONT
FAM: DT TRACKING: 10802T15 MY:2022
SCHEDULE D TO C TRACKING
SALES TRACKING
FUEL FILL/BATTERY CHARGE
ALLOCATION TRACKING
EASY ORDER
SALES DISTRIBUTION TRACKING
UNITED STATES REGION GROUP
NAFTA REGION
10 03/23/25
