Add a 12vdc under the dash
saglivid2772
Good morning everyone and happy thanksgiviing... I need some help, i want to add a 12vdc plug hidden under the dash for a dashcam. has anyone tapped into existing power and done something like that?
you do not need to do that
just get one of these, it uses the power at the mirror
Ensure the power port lighter fuse is set to ignition, then stick a thin spade terminal in the unused battery side. There's your B+
The power port fuse space has three terminals, run/load/B+. Moving the fuse from side to side allows you to switch from one source to the other.
