7" EVIC ghost images and inconsistent illumination
BOOMGUY
Hey y'all
2019 Lone Star with a 7" EVIC that is suffering from ghost images and poor illumination of the right upper corner...oh, and the range calculation is WAY off.
So every time that I fill the tank the Range estimate is 1999 miles and it slowly dwindles down over the course of the tank at a rate much higher than the rate of consumption because I suppose it is getting more and more accurate as the fuel level dwindles. The fuel gauge works fine so I could get over that and accept it if that was the only issue.
However, as shown in the attached photos, when I change pages in the display there is a ghost image of the old graphic for a minute or so. Even the green ECO indicator leaves a ghost image when it deactivates. Has anyone else had a similar issue? While the top right corner doesn't look awful in theses photos (although it kind of a pale gray rather than the blueish of the others) it is nearly unreadable in daylight because the digits are such a similar color to the background.
