you misunderstood the description on theseI'm installing these atm as well but it seem like the rear shock doesn't lift the truck as claimed? I got the adjustable ones that States 0-1" rear lift but after I installed it and measured it seems to be just factory heights ? Am I doing something wrong
Edit: I also don't have the factory off road package
You can go 1.5" on front with ORP or 2" without ORP and should make it almost perfectly level. With slight nose downSeems like if that's the case i may have to keep factory heights for the time being. I think the lowest I can prob get away with via the front I'd 1" and I think that may make it higher than the back hmmm
Oh? Thanks for the info! I'll double check it again tmrw! Base on your statement I'm assuming the back (without orp) sits at a little above 2 " ? I do want to keep a small rake just in case I gotta load up the bed with some heavy stuff in the near future.You can go 1.5" on front with ORP or 2" without ORP and should make it almost perfectly level. With slight nose down
