Lzielke
- Jun 22, 2021
Would you say overall that the E-Torque is not a good motor choice and to stick with the regular Hemi as my neighbor has been looking at that motor for when he orders.When its hot and you are calling for HVAC the stop/start will not operate until you get the cab temp close to where you‘re asking but you will not get the Unavailable message. The cause of this is almost always a low voltage issue caused by either the intelligent battery sensor or the MAIN battery being less than optimal. Your voltage meter in this photo looks like its lower than mine normally Is. You can check it by toggling the menu. It should be in the high thirteens to low fourteens in my experience with both my Rebel and Jeeps with Start/ Stop.
Can you explain more of what you mean, so does someone have to shut off this A/S/S when they want to run their Air conditioning at full function?I just turn OFF A/S/S via the button when I want to run the a/c full function at stops.
In my experience with e torque it has worked flawlessly for what it does. It’s the same 5.7 Hemi with a different charging system & with stop start plus regen braking. There have been a small number of e torque briefcase batteries fail comparatively but the main battery is usually the issue e torque or not ( it’s the same main battery in any non e t 5.7 Hemi Ram, jeep etc.) when the electrical stuff starts going wonky on these trucks. They are just so voltage sensitive. I wouldn’t be apprehensive about getting another e torque if it was the truck I wanted. The components are mostly covered under the emissions warranty coverage which is the longest term of any like 80,000 miles.Would you say overall that the E-Torque is not a good motor choice and to stick with the regular Hemi as my neighbor has been looking at that motor for when he orders.
Good to know.1.5 years and 12k miles on mine. No problems at all. First vehicle I've ever had with S/S where I don't turn it off immediately. It works well (even if it doesn't actually improve MPG).
Good to know, as I was concerned mine would do the same as the other guy reported that his was having battery issues when running his AC. Make you wonder when they do Quality checks if they work better during the week and less on Friday's Lol...1.5 yrs & 14,000 miles & works flawlessly.
In a/s/s, the engine is OFF, there is nothing powering the compressor, so during a/s/s the a/c is not at full function. the batteries are still powering the fan and electronics, however.Can you explain more of what you mean, so does someone have to shut off this A/S/S when they want to run their Air conditioning at full function?
If u turn your air up a notch the truck will turn back on to accommodate the cooler temperature. I usually turn my air down right b4 I know I'll be at a long light so my truck will turn off to save gas. It's been hotter than crap here in Minnesota so far this June. I work outside all day in construction, & the A/C is too damn cold imo. Idk what everyone is complaining about the air not being cold. Works too good imo.In a/s/s, the engine is OFF, there is nothing powering the compressor, so during a/s/s the a/c is not at full function. the batteries are still powering the fan and electronics, however.
Thank you for the explanation.In a/s/s, the engine is OFF, there is nothing powering the compressor, so during a/s/s the a/c is not at full function. the batteries are still powering the fan and electronics, however.
What if you were to just use it on a lower setting and not blast it as much, perhaps you guy's in Minnesota should be used to the cold AC in the summer, isn't it cold as hell there in the winter. Hell us folks up here in Massachusetts snow blow our driveways in our shorts. and flip flops somedays as it isn't cold enough for us here.If u turn your air up a notch the truck will turn back on to accommodate the cooler temperature. I usually turn my air down right b4 I know I'll be at a long light so my truck will turn off to save gas. It's been hotter than crap here in Minnesota so far this June. I work outside all day in construction, & the A/C is too damn cold imo. Idk what everyone is complaining about the air not being cold. Works too good imo.
