4x2 limited w air suspension. Anyone leveled?
Darlott
Just bought 2020 4x2 w air suspension and May have made a big mistake. Has anyone leveled? I keep being told can’t be done .....
It lowers even more at certain speeds for fuel efficiency. It is my understanding it sits higher in the back to compensate for payload and/or tongue load....
Yes people have did it. Search for the daystar level air ride links
Can confirm. Just did daystar spacers with revel links this weekend on 2wd limited with air ride
must be only the 2wd version. My 4wd sits level.
Check this thread. Works the same for 2WD as 4WD. Welcome to the forum and go get your truck leveled and some new tires or wheels/tires.
I have a 19 Limited 4WD, currently only have the Revel Links installed, but installing the Day Star spacers hopefully in the next week or so. Have 285/55R22 Nitto Ridge Grapplers going on tomorrow or Thursday.
AirLinks work also .I like the one that lowers the rear 3/4” and the front about 1.25”. Also they are only $100 for all four . They have pins to lock them in.
You might consider the 305 45 22 Ridge Grapplers they weigh only 48 lbs . Compared to the weight your adding . Mine are wider just fits inside the wheel wells and they are 32.8” height and I get great gas mileage . I can send pics if you want. Also this size is $50 less per tire than the other size.
I should look at dates. Before I post lol
All good. Thanks for the reply anyway. I thought about the 305s, but I went up in height both front and rear when I installed the DayStars, links and control arms. The 305s would have looked small on the truck I think aside from the added width which would have been nice...couldn't bring myself to do the 35x12.50 although I may switch to that after this set runs out. Truck doesn't like OR2 very much anymore, but who cares when you can almost never use it. I'd much rather have a bit more height in normal mode than the ability to go up in height up to a max of 25 or 40 mph.
A couple pictures for reference.
