Yes, I see that in the manual. But do you keep it on all the time?You could leave 4WD Auto on all the time as it won't hurt anything. It will only kick in when it needs to.
No, I'm not looking for "Set it and forget it". I just wanted to see what others do and their experiences with 4wd auto. I just bought my Ram and haven't used 4wd auto yet. My default thinking is to not use it all the time, just when the roads are slippery. But since I've never had a truck with this option I just wanted input on it from fellow truck owners.I'd maybe turn it in winter on but wouldn't leave it on if the roads are completely dry. Are you trying to "Set it and forget it"?
Only when conditions dictate, e.g. variable inclement weather. It won’t hurt anything but gas mileage (a bit) to run in Auto 4WD continuously. But as others have said, it’s unnecessary in good conditions.Do you use 4WD Auto all the time or just when road conditions dictate usage?
I’ve had 4auto for 14 years now and I love it! Do not leave it on all the time. I use mine when it’s slippery in town at stop signs/lights, I really like it for that. As others were saying, maybe in the rain, if roads are slick and you want piece of mind that it will kick in if you have wheel slippage. Also if you need to pull out in traffic fast, this will give you extra traction and prevent as much wheel slippage, just remember to turn it on quick! I also use it if know I will have to stop on a incline with loose gravel or rocks, sand etc. I have used it in deep snow and it works fine, but for best results in deep snow or roads covered in ice, you would have the best results in 4H. Good luck, enjoy the new truck and the auto 4WDNo, I'm not looking for "Set it and forget it". I just wanted to see what others do and their experiences with 4wd auto. I just bought my Ram and haven't used 4wd auto yet. My default thinking is to not use it all the time, just when the roads are slippery. But since I've never had a truck with this option I just wanted input on it from fellow truck owners.
^^Exactly how I've been using it. 2wd most of the time, but I will kick it into 4A or 4H under those same conditions.I’ve had 4auto for 14 years now and I love it! Do not leave it on all the time. I use mine when it’s slippery in town at stop signs/lights, I really like it for that. As others were saying, maybe in the rain, if roads are slick and you want piece of mind that it will kick in if you have wheel slippage. Also if you need to pull out in traffic fast, this will give you extra traction and prevent as much wheel slippage, just remember to turn it on quick! I also use it if know I will have to stop on a incline with loose gravel or rocks, sand etc. I have used it in deep snow and it works fine, but for best results in deep snow or roads covered in ice, you would have the best results in 4H. Good luck, enjoy the new truck and the auto 4WD![]()
Ditto.I only use it when there is snow or ice on the ground. If not 2WD all the way.
