4th Gen exhaust on 5th gen
Cherneski
Hey guys.
Came across a really good deal on a cat back exhaust from a 2016 1500 crew cab. I have a 2023 crew cab, same trim (Sport model in Canada). I have a new body style (DT).
Is this a simple swap out? Or will things need to be added /rerouted and not worth it?
Thanks!
Also, in Canada, "Sport" is it's own model. When searching for parts... Is this compatible with Laramie, bighorn, Rebel, etc? My build sheet says REBEL LEVEL 2 EQUIPMENT GROUP. So does that make it a rebel? Or can the Laramie and Bighorns have the rebel equipment groups too?
I have attached my build sheet as well if that helps as well!
  • BuildSheetServlet.pdf
Too much difference between 4th and 5th gen exhaust to make it worth the time
