4in or 6 in
ayoslickxd
which should i get bds 4 inch or 6 send post pics pls
Here you go: I went from BDS 4” lift up front & 2” spacer in the rear with 35s, to BDS 4” lift all around with Bilstein 5100s set at 1.7” up front with 37s. The nice thing is that the BDS 4” and 6” kits are the exact same, the only difference is the height of the spacer in front & the length of the coils/shocks/end links in the rear. All your drop down brackets are the same part #s though. Which means technically running it at 4” height makes your control arm angles & CV axle angles a little better. 9F21AE6C-DFFC-470E-B52D-F63BB18856AE.jpeg75CC71FA-1901-4B2D-AD5E-52029A34D404.jpegB9A635F3-7C14-4E3F-AAAD-A47FD9BB5FF3.jpeg4F669BFF-7887-4D6C-B668-F9E4941D3CB7.jpeg
yea im thinking going with 4 inch lift. i have a rebel eco diesel with fox 2.5 coilovers, they told me i need bds lift kit 4 inch because the ecodiesels have ssomething shorter … i have the coilovers at stock height … no rub but one spot and it barely rubs… so i wanted to raise the coils about a inch more … they saying that would be the proper way to fix the rubbing …(i feel like they just wanna get me to buy the bds kit) now my question for you guys would be just raise the inch more ?
get the bds 4 inch lift and coil overs ( which they said the ones i have would be no good anymore and need to put a hat on top ) so i should just buy ones that come with the bds kit
or just do a 6 inch lift 😅
i feel like 4 is good for the off roading i do ….
also
i also kinda like the 37s on 18s 🥹
also
Ok so to answer your questions:
1) Why don’t you just trim where it rubs?
2) No you don’t “need” the BDS kit, you can either adjust the coilovers or put a top hat spacer on for an additional one inch lift for a total of 3.5”. Just make sure to buy aftermarket upper control arms!
3) The BDS 4” kit is not offered with coilovers, but if I were you & already had the 2.5” ones then just put a 1.5”-2” spacer on top of them. It will ride the same and have the same performance as your current setup, just 2” taller. With this you should not run aftermarket UCAs.
4) I want to run 37s or 38s on 18s also. I think your best bet if you want to run tires that large would be to get the Zone or BDS 4” kit, use your current coilovers & add a 2.5” spacer on top, and do 37x12.50s. But with that you’ll probably have to trim also haha which is why I say maybe just trim your current setup and then down the road do the bigger setup
so if i dont get the kit just get control arms and top hat spacers? do you think i would run into drive shaft issues in the front i read a bunch the ecodiesels was shorter and stuff like that. hence why they was saying i needed the bds kit
also if i did the full bds kit was just gonna sell my current coilovers which i. had for one season …
im honestly just looking for a bit more clearance i off road the truck also in vermont and in snow 😅
but i was thinking 37 x 12.5 tires also
yes im on the ropes of just geting the bds like you said and trimming and just addd 37 hahah
seeing your truck it looks so good
my current set up is stock rebel height at 305/70/18
ahhh i saw what you meant now i should just get the 6 inch lift then it comes with the coilovers
also i was looking and it shows with the 6 inch lift kit still they use the same size coilovers i have which is fox 2.5 dsc i think part number MPN#: 883-06-166
maybe they just use a bigger spring ?
It’s a 2.5” diameter coilover but the shock & coil is longer obviously to lift it
ahh ok ok. so for the 6 inch lift i would be using that coilover… is the 4 inch coilver longer also?
There is no 4” coilover unless you got some custom made, but yes it would be longer because that’s what’s lifting the truck
Mclovinnnnn, truck looks good. Ayoslickxd, here are some pictures of my 1500 with BDS 6" and Fox 2.5 front and 2.0 rear, running 35's on 20x10 -24. She’s dirty but I hope the pictures help with your decision. 044A4D89-4194-411F-BE16-32924F150495.jpeg1C8F3CBF-EEFA-4CF2-AAA2-1E98893BBBCE.jpeg15381C43-AE48-432D-B45F-8C8C2320596D.jpegAE4FFD06-038C-4C34-A0C4-300F14F78456.jpeg
Mclovinnnnn, truck looks good. Ayoslickxd, here are some pictures of my 1500 with BDS 6" and Fox 2.5 front and 2.0 rear, running 35's on 20x10 -24. She’s dirty but I hope the pictures help with your decision. View attachment 131502View attachment 131503View attachment 131504View attachment 131505
Thanks man your truck looks great too! I’m surprised you can see the black wheels so well in the pictures. Maybe it’s because the truck’s gray so the camera isn’t picking up as much contrast. Because with my white truck I can hardly get the wheels to show up on camera lol
yea i think im gonna go with a 6 inch lift just looking now for parts
