3d Printed Ram stuff
Not that I'm aware of, but would be cool.
I did some plugs for the bed to keep dust out, but that's all I've done so far.
What is the purpose of those holes in the bed railing? I' was thinking to put those plugs in as well.
They are a hold over from the old stake pockets of older trucks. I've never seen any reason for them on newer trucks. Maybe some aftermarket racks use them, but I don't know.
FWIW, the Rambar (which is an OEM part) uses the front stake pockets.
Search the usual databases too. Thingiverse, printables, grabcad and the many others out there.
Not those holes. The ones inside the bed. "inside" the tie down loops.
3d printed custom badges. Veteran and fellow 5th Gen Ram owner
Maybe I'll put it on the Tailgate so it's staring at whoever is behind me.
I also want it to blow smoke and maybe shoot some water or vodka out?
Yes, it's what u said. That's where my drain tubes go on my Rambox bed.
No, the left arrow. Under the ring is a blank space. Not the round hole on the right arrow. If your drain tube goes under the ring, you installed it wrong. You should run it down the hole on the right. The round one.
Yes I can see. It goes into the left arrorow as it doesn't fit in the circle one, the tubes goes straight and hits the inside of the bed and doesn't drain properly.
Do I need to show pictures lol?
