1jmicheletti
- Feb 6, 2019
Will Nitto Terra Grappler G2  35x12.5x20 tires fit on 2019 Ram Laramie Sport 4x4 with no lift kit?
			I just put 35x12.5x20 on my 2019 laramie sport with a 3.5in readylift and i had some rubbing. Trimmed it and its fine but you would definitely have issues i feel like. Mine is 2wd though. Droppin some pics for yaWill Nitto Terra Grappler G2 35x12.5x20 tires fit on 2019 Ram Laramie Sport 4x4 with no lift kit?
I appreciate it, its fun making these trucks your own!Your truck looks very strong - I will give it try once I get my truck in May - thank you
My white sport goes in Tue for the same set up! Ive been thinking 12.5 but might switch to 11.5 . Do you have a 0 offset on 20x9 rims? Also does that 35x12.5 stick out past body?
Ive got about 2.5" that sticks out past the body. I'm honestly not sure what the offset was before, its at -44 now with a pretty aggressive stance. I love it though! Hopefully that gives you a better idea of the look with that pic.My white sport goes in Tue for the same set up! Ive been thinking 12.5 but might switch to 11.5 . Do you have a 0 offset on 20x9 rims? Also does that 35x12.5 stick out past body?
What offset on the wheels?I just put 35x12.5x20 on my 2019 laramie sport with a 3.5in readylift and i had some rubbing. Trimmed it and its fine but you would definitely have issues i feel like. Mine is 2wd though. Droppin some pics for ya
-44 on thoseWhat offset on the wheels?
You must of had some major rubbing! Do you have 3.21 gears in yours? Truck looks sweet!-44 on those
Not without some issues- Prob not a good ideaWill Nitto Terra Grappler G2 35x12.5x20 tires fit on 2019 Ram Laramie Sport 4x4 with no lift kit?
