35s
ElBearded
I’m looking to put 35/12.50 R20 (falken wildpeak at3w 35’s) on my stock 2020 1500 bighorn. I’m trying to find out if they’ll fit without putting on a leveling kit? Thanks!
You will more than likely have to do a lot of cutting. I have a 6 inch on 35s and had to cut. If you go to the custom offsets gallery, you can see how tires fit on different rigs and what they had to do to get them on.
I have a roughly 3” lift. Rebel so a factory 1” lift then Bilstien 6112 shocks giving me another 2”.
I have what equate to 35x11.5 and I did not have to trim anything.
I’m a huge fan of the AT3Ws myself. I looked at them online and I think it said they were 70lbs a piece, report back how they are if you get them. Curious about feeling the tire weight with acceleration and if it’s really that noticeable.
I ended up with the AT3s but in a 33” tire. As of right now I don’t have any leveling kit installed up front, but I think I’ll have to because there is some rubbing when I turn the wheel all the way in either direction. Aside from that, the tires look and drive amazingly well. I was surprised at how quiet and smooth they ride! I’ll attach a couple close up photos of the new tires. I’d highly recommend so far!
I didn’t notice a difference. Great tires. Details in signature.
Did you use the spring that came with the 6112 or the factory spring? Also did you measure to see if you got a full 2in lift?
