35's with -24 offset and spacers
sooter21
Hey everyone! I'm sure this has been asked and I just didn't find it anywhere.
I'm in a 19 Bighorn that has been leveled. I want to put 35s under it, which I know will technically fit with the stock wheels, but I'm not running stocks anymore. I've got the Mayhem Warrior 20x10 Black Milled, which has a -24mm offset. It gives it just a bit more poke than the stocks, but I want more. If I put a 1.5" or 2" spacer on and then 35's, how much modding will I have to do to the front wells? I don't have the bandwidth to do lots of mods right now, but will in the near future, but I definitely need new tires now, so I'm trying to decide if I go without spacers for now and add them later or if I will be ok to add the spacers and just use a heat gun to re-mold the fender liner a bit. Will that be all the modding I need, or will I have to trim the pinch weld too?
Here are pics of how it looks currently with the 275/55r20s on it (my truck looks like I've been skipping leg day for a while). I like the look (minus the chicken legs), just wanting a bit more aggressive stance.
1.5 - 2" spacer will give you roughly -62 to - 74 total offset. You'll have to lose the flaps and probably cut quite a bit out of your pinch weld to make those fit. You're on 32x11" tires right now, moving to 35x12.5 adds 0.75" then another 1.5" farther out with a spacer.
