I don't have exactly what you are asking for but here is mine: 305/70/R18 (35") +1 offset. I only have a leveling kit and no rub after slightly trimming and bending the plastic in the fenders (probably didn't need to trim at all once I got the plastic to move). I think the +1 offset was perfect.
Thank you I appreciated looks good !!! But I think +1 will stick out for me bc I don’t have factory flares that come on some of them I have -24 now 20x10s on 33s but I’m sick and tired of **** flinging everywhere hahaI don't have exactly what you are asking for but here is mine: 305/70/R18 (35") +1 offset. I only have a leveling kit and no rub after slightly trimming and bending the plastic in the fenders (probably didn't need to trim at all once I got the plastic to move). I think the +1 offset was perfect.
Thanks. These are Mickey Thompson Baha ATZs 305/70/R18What tires are you running? Super clean setup.
				You are right, they will stick out a bit without the flares. +6 or +12 would suck them in where you want it. Couldn't say if it will rub or not but I think you would be OK if you use a heat gun to bend the plastic out of the way.Thank you I appreciated looks good !!! But I think +1 will stick out for me bc I don’t have factory flares that come on some of them I have -24 now 20x10s on 33s but I’m sick and tired of **** flinging everywhere haha
Gotcha worse come to worse I think I’ll go with the ready lift 3.5 says 35x12.5r20 will fit with 20x9 +18 so all most like factory offset which should keep me inside fender if not do dealerships sell them own painted flares I think the put them on the laramieYou are right, they will stick out a bit without the flares. +6 or +12 would suck them in where you want it. Couldn't say if it will rub or not but I think you would be OK if you use a heat gun to bend the plastic out of the way.
