35" on stock 22 inch wheels and stock Limited Air suspension
Rmazzei
On various forums I see people running 35 X 12.5 X 22 on Stock wheels with air suspension without a lift. They are claiming minimal rubbing which is fixed with wheel well trimming. Is this really possible? Anyone with first hand knowledge on this? Currently running 305/45/22 which are about 32 X 10 X 22. Cant se how the 35s fit.
YouTube ram leveled on 35’s and find the guys with limiteds or longhorns with air and 90% of them have just the level links for the air suspension. Some Have the day start leveling pucks and leveling links. The videos show they turning tires and where they could rub or where they do or don’t. It’s close and depending exactly why tire brand you go with some are 1/4” smaller or bigger and make the difference. It doesn’t rub to where you have to grind metal or anything for sure. It only Rubs on plastic so even if you do rub you can heat and stretch or zip tie liner back a little.
