33” x 305 55 r20 Fit on stock height no rubbing !
Ty9122
Title is explanatory ! Many people thought a leveling kit would be needed to fit these wheels ! I can confirm that they fit at stock height no rubbing !
Is this on a truck with air suspension?
I run them. 305/55/R20 nitto ridge grapplers. Tires "will" rub if you reverse quickly and turn the wheel full crank. (just sayin)
UPDATE ! tires do not rub anywhere in the wheel wells but there is very little space between the sidewall and the upper control arm 1/4” tops kind of worried about that
Sounds like 295’s would be better fit
Yep or a offset wheel instead of the stock wheels to push it out a bit more
