325/60r20
Mazzman28
Will these work on a 2020ram 1500 bighorn? It’s factory but am willing to put a lift and what lift / spacers do you suggest?
MikeyHo808
Hawaii
Most definitely would not fit a stock setup. That is a lot of tire (35.4” tall, about 12.8” wide) and a lift would be in order to clear. Don’t think a level will be enough…maybe with some trimming.
Options available depend on stock setup too, as well as wheel setup, etc. I have 33x12.5 wide tires and needed 3/8” spacers to better clear the UCA’s.
But many on here have Rough Country or Ready Lift 2.5-3.5 lifts and are pleased with the results. Some research in the suspension section of the forum will yield a ton of results. Good luck. 👍
Mazzman28
Thanks for the info might have to go with a 4-6” Lift and it should work right?
SKT Customs
5thGenRams Vendor
5thGenRams Vendor
San Diego
Those tires will fit on a level, there’s been some people running them. Just don’t run super wide wheels. Probably want to do close to a 0 offset and just do some trimming of the pinch weld.
