I’ve been looking at the same ones and the toyos and there shud be no trimming to little.... they shud fit no problemI’m been searching and haven’t found a definitive answer if the 305/55/20 xl ridge grappler will fit a 4wd on stock wheels and suspension .
I have the same tires on stock but with the off-road group so it has an extra inch to play with. these have the slightest off rub at full turn backing out of the driveway but not always so it depends on what pump i hit. So I'll guess you will have a more consistent rub at full turn but I read of others with your exact set up that claim to have no issues.I’m been searching and haven’t found a definitive answer if the 305/55/20 xl ridge grappler will fit a 4wd on stock wheels and suspension .
I asked 4 wheels parts that same question but I want a level lift. He said a fab tech 2 inch level lift would everything work fine.I’m been searching and haven’t found a definitive answer if the 305/55/20 xl ridge grappler will fit a 4wd on stock wheels and suspension .
