Here's some photos of my new tires: Michelin Defender LTX M/S2 in 305/45/22 on stock wheels. No lift or spacers. There was very slight rubbing on each front side which i fixed with a zip ties. Easy fix. So far only about 800miles on these tires (only dry - we didn't have any rain here in NY for almost 2 months). Tires ride a bit softer than stock setup. I keep them at 35-36PSI (I find anything above 36PSI makes the ride too harsh), acceleration is tiny bit slower and breaking requires a little more pedal press but only very "sensitive" people will notice it. I installed "pedal monster" which fixed the delay or hesitation when accelerating from stop and this in turn feels like the truck is even faster then with the OEM tires. Handling at highway speeds is also noticeable better.
I did not adjust my speedo yet. MPG loss is about 1mile. I used to average about 17.5 mpg, now about 16.5 mpg but once I adjust the speedo this will get slightly better. Driving noise is the same as stock, no difference.
Not very visible on the photos but these tires stick outside the rim about 1" (OEM is less then 0.5") which is great if you are concern about curb rash. So far so good - I didn't have to be so careful around tight spaces.
Besides being a bit wider (12" vs 11.2"OEM) these tires are also a little taller 32.8" vs 32.1"OEM). Overall I am happy with my choice but I want to see how they handle in rain and snow.
(My truck: 2022 Ram 1500 Limited with air suspension, HEMI 5.7 with e-torque, 3.92 gearing)
