Apettit13
- Oct 6, 2020
Hello all, I’ve been rummaging through some old threads and haven’t found anything in regards to this setup.
I installed a 3 inch front, 2 inch rear Motofab lift a couple of weeks back. I already plan on replacing the UCA, but as far as tire size goes I’ve hit a roadblock. I would like to run 35’s, but I would also like to run a 20x12 -51mm offset wheel, im under the assumption that this won’t work as the offset is pretty aggressive? Would I be able to run a 35 inch tire if I dropped to a 20x10 -25mm offset?
If anyone is running a similar setup would you mind posting and let me know if there’s any run/trimming that needs done?
