3.5in ready lift uneven
stippLe
Texas
So I installed 3.5" ready lift
The passenger rear is a inch higher than the drivers rear?
Did I do something wrong?
I have front c
Struts compressed at actual off road shop.
I have front c
My truck came stock .5” higher on the passenger rear than the drivers rear so there is some difference in the way the suspension is set up to begin with. If you installed the rubber boot wrong or different on top of the coil spring from one side to the other that could compound the issue. I also think the amount of fuel the tank has in it makes a difference.
