3”-3.5” lift recommendation
LonghornRik
Texas
trying to figure out front suspension for my 2021 ram 1500 Longhorn. I have rear 1.5” icon springs and shocks as well as front UCA. The icon front coils I bought (second hand but brand new) only lift the front 0-1.5” so need an alternative to that. What would yall recommend for 3-3.5” lift in the front? Would like to do a coilover instead of spacer but not a lot of options.
The Bilstein 5100's or the Eibachs will give you close to 3. Not quite but very close. I don't recommend anything lesser than those because you are getting into cheap products and not saving money at that point. With either of those you can keep your rear springs and have the right amount of rake. And your Icon UCA's will work great with either of those choices.
I ran an ICON Stage 2 set up on my23 Laramie non ORP. Got 2 5/8" in front after it settled. Did you adjust the coilover or just install as is?
