Went with 20x10-18 with 35x12.5 with 2 inch front 1 inch rear level kit
can we see a pictureWent with 20x10-18 with 35x12.5 with 2 inch front 1 inch rear level kit
Tires in the garage and wheels coming in on Tuesday. I’ll post picks when installed.
If I’m not mistaken it’s around 85lbsHow much those weigh a piece ?
just want to make sure 35's fit with level kit ? not doing UCA. wheel is 18x9 -12 want to go with 35 12.5
I’ll end up removing the mud guards and might to to trim the metal tap that holds the guards as wellI’m running 285/65r20 (34.6”x11.2”) and they rub sometimes at full lock in reverse
Looks good. Noticed you removed the mud flaps..
I don’t have the air suspensionWhat about rubbing on the UCA when aired down?
can we see some side shots when you get a chance? and some to see how far the tires poke out? i have a red rebel as well so this post is perfect. truck looks awsome.Here’s how she looks with the rear level installed
