295/60/R20 on stock
Sorry- tried searching this and can't get a clear answer. Will a 295/60/R20 fit a stock 21 Laramie 4x4 without a level? Or can anyone point me to a good thread? Custom offsets has examples but they all say "stock lift".
Most likely it will fit. I have a lonestar with 2.5" level up front and I fit 295/65R20 easily. Height of the tire wasn't an issue at all. I was close when it came to the width, but with the level moving the wheel down out of the wheel well, it put the widest part of my tire at the widest part of the wheel well. So I have no clearance issues and no rub. My main point of concern was side wall gap between inside of the tire to the upper control arm. But that clears too by a finger.
295/60R20 shows to be a 33.9" tire, so the width is what will possibly get you. If it does, it would likely be on the little mud flap on the back side of the wheel well. Front side of the wheel well doesn't really have anything extra to protrude out.
What tire are you thinking of going with? Tires tend to measure out differently once in person than what their specs say. For example I have Yokohama Geolandar M/T's, which measure out taller than other brand/tire 295/65s, but measures out true to size with width or slightly narrower. Whereas i've had Nitto Ridge Grapplers measure out slightly shorter than equivalent sized tires, but also a good deal wider. So a Nitto Ridge Grappler in 35x12.5 I had measured out to about 33.5"x13" once I had them mounted.
Thanks for the info. Looking at
Micky T Baja A/T
All I can add is that I have 295/65 R20's on my '21 Laramie WITH a 3" front/2" rear lift/level, and I still had rubbing in the front @ full lock. I had to remove the front mud flaps and secure the wheel well liner to stop the rubbing. I think you may be alright though. You are looking at a somewhat smaller tire and have the factory 1" lift, but there is always a chance there will be a little rubbing.
What tires do you have? I did have the thin liner on my passenger side rub but it was curled outward from what I assumed was engine heat. Snipped a small 1 inch triangle piece off and that fixed it.
I have 295/60R20 tires on stock Laramie sports. 1/4” spacer and a 2” level and OEM ORP rear spring for a Ram box bed. My drive is on a hill.. so looks kinda off in the photo as there is a curve in the drive.
Yokohama Geolandar A/T G015's
I have a 2-in ready lift leveling kit on my 2019 running on stock wheels 295/60R20 Mickey Thompson Baja boss AT no trimming no rubbing fit just fine
