Thanks, I am looking for an AT tire but this looks much better then the 285s! did you notice any rub?I just had Michelin 305/45-22 installed today. Changes are only 0.7" added diameter, but I like the looks of it. Doesn't look as skinny anymore. Also, that size Michelin is rated for 9" wide rims, so stays within spec of OEM rim, saving me some money.
Slightly wider tire looks good as well:
I have the 22 ram limited with air ride suspension. Do the 30545R22 tires rub? I want to go with larger size as wellI just had Michelin 305/45-22 installed today. Changes are only 0.7" added diameter, but I like the looks of it. Doesn't look as skinny anymore. Also, that size Michelin is rated for 9" wide rims, so stays within spec of OEM rim, saving me some money.
there is a slight rub, on the passenger side only, when reversing with the steering cranked over hard. Could probably easily fix it, but have not gotten around to it.I have the 22 ram limited with air ride suspension. Do the 30545R22 tires rub? I want to go with larger size as well
how wide are the 305 45R 22 Michelin'sI just had Michelin 305/45-22 installed today. Changes are only 0.7" added diameter, but I like the looks of it. Doesn't look as skinny anymore. Also, that size Michelin is rated for 9" wide rims, so stays within spec of OEM rim, saving me some money.
