275/60r20 BFG KO2’s
I have the same tires. Superior traction. They are a little noisier at speeds around 27-37 mph,
after that very quiet. Snow and wet traction is awesome.
Whats the width and offset of those wheels?
Looks awesome!!! Do you think you could of fit 285/60R20 KO2's with no rubbing keeping everything stock with no off road or air suspension. Any input would be greatly appreciated,
I believe it would rub, you’d have to do some trimming or get a leveling kit.
I have the same truck just black and have the same wheels. Looks good sir. It is hard to tell from the pictures, could you have gone bigger at all? Either 275/65/20 or maybe 285/60/20? Or is that the biggest that will fit?
Hey there, I’ve finally pulled the trigger on a new set of KO2’s for my 1500 Sport crew cab 6.6 box
After much much debate, I ended up with the 285 60 20. No level everything stock and zero rub so far.
Tire installer inflated them to 40. I called BF and they recommended 48 psi. The tire is an LT tire and 10 ply. The sticker ratings on vehicles is usually P tires that are OEM
No rubbing here running 285 60 20
So yeah.. Hoping I can fit this exact tire on my Big Horn with no lift of any type. Can you please verify your stock setup? Thanks!
