25 Ram die batteries 4 times
Eddie@1846
I have a 2025 Ram SST that if my truck sets three days it will kill the battery,The dealership has put two sets of batteries and it still kills the battery,It’s been to the dealer 4 times and they still haven’t found the problem,I bought a battery jumper to carry with me,They have contacted the head technician and nothing has changed,I like the truck,But I have to drive it just about every day,I’m retired and don’t drive every day,But I keep the truck so it just doesn’t set at the dealer,Hopefully that they will find out what’s wrong , I have had a software updates,Still nothing has changed IMG_1733.jpeg
Had to get batteries replaced on my 2025 last week. No indication from dealer as to why the went bad on brand new truck.
You have a parasitic draw that is draining the batteries. Desert should be diagnosing that, and not just replacing batteries. But they would need to keep the truck for several days to diagnose
100% agree. It will take some time to troubleshoot. Dealership can't fix it if you have the truck in your garage. Take it back if you don't want to have to keep your truck on a charger.
I let mine sit and didn’t drive for one day, batteries died. Was at 2v. I changed the batteries myself both main and aux. hasn’t died but in the run position the battery voltage shows at 12v in red. Does anybody else’s voltage in red or is showing a low charge?? In running position with truck on voltage is shown in white numbers.
mine starts at 12.6 and slowly drops, in red the whole time, unless I have just shut off the truck.
I also have a 2025 Laramie . I noticed something running under the hood for about thirty minutes after its shut off. the dealer found both batteries bad and replaced . does anyone know what it is running ?
Coolant pump for the turbo
Brand new 2025 Rebel x edition, battery has died 2 times in 2 weeks... seems to be when it is very cold at night. Dealer has just ordered me a new battery.. being installed in a few days. Tow truck company who boosted me says they boost Rams every day here in Ontario Canada... seems to be a bad batch of batteries. This is my 6th Ram in 20 years, and never a problem like this. I also saw a thread on parasitic drains, but who knows what is causing this? FYI, dealer ran codes on the car, and it shows nothing wrong. Also not leaving any cords plugged in either.
Sorry to hear it.
Would be nice to find out what percent of trucks are having these issues... it it 10? 1?
Forums seem to shade to the negative, so whose to know.
I've been reading that if guys leave the key fob near or in the truck its draining the batteries... not sure if you do or not but I keep both fobs inside house far away... there's been bad batches of batteries from factory before I had that problem with my 2022 2500, I switch out my battery first day to something like optima or odyssey. never had a problem on any trucks since and I've had 4 in as many years...
My key card was in my center divider when this happened to me (dead batteries), no idea if its related, I removed to prevent being stranded again.
See if the dash is staying lit after you exit vehicles. Many are having issues push brake to start staying lit on the dash when they exit and draining the battery.
I have a 2025 Ram SST that if my truck sets three days it will kill the battery,The dealership has put two sets of batteries and it still kills the battery,It’s been to the dealer 4 times and they still haven’t found the problem,I bought a battery jumper to carry with me,They have contacted the head technician and nothing has changed,I like the truck,But I have to drive it just about every day,I’m retired and don’t drive every day,But I keep the truck so it just doesn’t set at the dealer,Hopefully that they will find out what’s wrong , I have had a software updates,Still nothing has changed View attachment 194683
I have a 25’ 1500 Rebel X less than 1200 miles and I have the 2 battery setup and have had dead batteries 4 times. Total of 7 replace batteries. They keep telling me it bad batteries and I’m tired of hearing that excuse. I had a shifter replaced, multiples of both batteries replaced, blown fuse, sun roof motor, and it is in the shop now while they replace a uconnect module of some sort not sure. They treat me like it’s a normal thing to have so many batteries die. Just bad luck. I don’t believe it. Software issue???causing some component to run and drain batteries.??? I don’t know, they don’t seem to know. I just started a case file today Ram. 1200 miles and it seems they’ve had it longer than me. Bought 2/14 7 (3/4)total batteries dead. Someone help me.
  • Like
Reactions: KS2
I have 2025 Ram 1500 Rebel X, they have two batteries. My batteries have been replaced so many times I’ve lost count. Could be 7 + batteries. Rebels have shifter. Mine has been replaced. Moon roof motor replaced. Uconnect module of some sort, replaced. Other electronics, replaces.
They don’t know what it is. Though they said it’s probably a bad batch of batteries. I think it’s bs of course but they are sticking to it. 2-3 days left without being started and I checked battery voltage…under 4 volts. Not even a small LED light would come on. And it could be jumped. Towed at least twice from home.
Fixing to have my 2025 towed in for the second time. Went out of town for 2 weeks and battery was shot when I got back home. Took in about 6 months ago the first time and all they did was replace the batteries. Mine is fine as long as you drive it often but don’t just let it set. I saw something earlier today about CAN bus star connector has resolved the battery drain for some trucks. Going to mention that to dealer when I take it in. Very frustrating!!
