'25 hotspot carrier options?
StuartV
Lexington, SC
I searched. I didn't find any posts about this in the Uconnect 5 era.
I'm supposed to take delivery on a '25 Limited this afternoon.
Is the only option for the carrier for the truck's hotspot still AT&T?
I have an iPhone and an iPad, both with Unlimited data plans on AT&T.
Is there ANY reason I would want to pay for the hotspot in my truck to be "turned on"?
I could see paying for the truck hotspot if it was on a different carrier. If I'm somewhere that has no AT&T coverage, but has Verizon coverage, having the truck hotspot on Verizon could be very useful.
But, if the truck can only do 4G/LTE on AT&T and my phone and iPad both already do 5G on AT&T, when would the truck hotspot ever be of any use to me? If I have passengers that need Internet, I can turn on the hotspot on my phone or iPad and let them connect to that.
It seems like Stellantis has dropped the ball on this. The truck should at least have two options for the hotspot, so people like me who are already on AT&T can choose a non-AT&T option and actually get some benefit from the truck's hotspot.
Not sure why you would need a vehicle hotspot anyway, especially when you answered your own question, " If I have passengers that need Internet, I can turn on the hotspot on my phone or iPad and let them connect to that."
Our phones can do that for you without any extra charges. Maybe, if you were in construction or something and it was a work truck I could understand it.
Umm...
I would like other options, I have Verizon and don’t really want to add another line from another provider. I’ve used the trial of the hotspot in the past and it worked but shuts off as soon as the truck is turned off, many times having to manually reconnect each device. Now I just use the hotspot on my phone or iPad when on roadtrips.
If it was the same carrier as what my iPhone and iPad are, I wouldn't get it. I already have hotspots and unlimited data on my phone and my iPad. What would be the point?
And... it looks like I won't. It IS the same carrier I already have.
I AM curious what it means to say that many times you have to manually reconnect each device.
Does the AP SSID change every time the truck restarts?
If the SSID is the same and the password for it is the same, then reconnecting automatically or not should be solely dependent on the device that is trying to connect.
E.g. my iPhone has the SSID and password of many WiFi access points stored in memory. Most of them are set to automatically reconnect. Some are set to manually reconnect. If my phone sees a SSID it recognizes and is set to Auto Reconnect, then it will. If the password hasn't changed, then the reconnection will work.
The only way I could see you having the issue you described is if you just weren't patient enough in waiting for your devices to detect the hotspot and then auto-reconnect. Sometimes, it CAN take a minute or two (or 3 or 4).
When I use my iPhone as a hotspot, it IS FLAKY AF. If I'm trying to work remotely and have my Windows laptop connected to the Internet via my iPhone's hotspot is just is ... flaky. But, that appears to be completely on the hotspot in the iPhone. It drops the connection (not just from my laptop, but from other things, too). When it decides to come back to life, I only have to "manually reconnect" if I am too impatient to just wait and let my laptop detect the hotspot again and reconnect automatically.
If the RAM hotspot is flaky like that, it would ROYALLY **** me off. My iPhone hotspot royally pisses me off every time I try to use it from my laptop. Same if I try to use the hotspot on my iPad instead. From what I've read, it sounds like it is well-known that Apple hotspots are like that and only really work "right" for Apple clients.
