23 to 25 power running boards swap
so I traded in my 23 and got a 25 w/ hurricane. I took my Mopar power running boards off to install on my 25. Was able to get everything except the wire harness. I see that for 2019-2024 models, the Mopar power running boards kit part # is
82215287AH​
and for 2025/2026 it is
82219228AB​
I see that for the 19-24 kits, there is a replacement wiring harness available to buy separate from the whole running boards kit. They call it “electric repair wiring kit” part # 68422689AC. What I’m trying to find is this equivalent for the 2025-2026 kit assuming there is just the harness available and that I can use it with the running boards/motor and control that I already have. I have alpha OBD and figure I can just activate it with that. Anyone know the part number for the wire harness if there is one for the running boards/hurricane engine ? If the wagoneer has the same (not familiar w/ it, I’ve just heard it had a hurricane motor) hurricane engine/running boards would that be an option to look in that direction for a harness ?
82215287AH​
82219228AB​
You can't use AlfaOBD on a 2025+ as is. You can't change settings unless you have specialized equipment. And good luck getting a dealer to do it if it can be done at all.
Wow that sucks. I’m probably better off buying the harness, making my kit whole and selling my boards then
