22 Badlander hemi
Plante1976
Started truck and every warning light and message appeared in message center…stayed on entire drive to work….1E492ACA-A044-4256-92BB-DA0F92BD4723.jpeg
Did it run ok? If so, you might try disconnecting the battery for a few minutes and then see what happens after you reconnect. It might look similar immediately after but could clear up. I would also recommend checking for loose ground connections at the frame near the battery
I'm assuming that based on your thread title your truck is a '22? Based on that I'm inclined to agree with HemiDude. However while it's unlikely it is possible that you got a bad battery from the factory. It wouldn't hurt to have it load tested. A weak battery causes all kinds of crazy issues with these trucks.
Problem solved. Thanks again
