2025 Rebel Level Lift
scj
First thing, all the MotoFab suspension parts I used were for ‘19 to ‘24 Ram 1500’s.
Stock, my truck was raked 2 7/8”. I finally decided to go with 2 1/2 inch spacers for the front end. Well, that netted exactly 2 7/8” lift making the truck dead level when measuring at the wheel well openings. I tow my boat often so not wanting to mess with air bags but not wanting to sport the rear end squat while towing, I went with 1 inch rear spacers. The rear spacers actually measure 1 3/16 inch thick.
The space gained over stock looks much better and with 1 1/8” rake, my boat doesn’t have my truck squatting.
I don’t think the upper ball joints look stressed but I bought the Mopar 2” lift upper A arms for peace of mind.
One thing to note; my steering stayed perfectly straight and the front end feels exactly as it did prior to lift. I’ll have alignment checked just to be sure.
Do you have air suspension on front at back?
I have a 24' Limited that I want to do the same thing to but read so many differentiating reviews, hard to decide what the best/right thing to do is. Any input would be great. Thanks.
No, stock springs front and rear
Did you go with 35in tires? I want to avoid rubbing and I had just a bit with the 2023 rebel and 2in readylift leveling kit. I cut out a little of theplastic inside and it was fine but tryingto avoid cutting on the new 2025 if possible. Why go with the rear spaces if you had it perfectly level after the 2.5in spacers. Im thinking about motofab 2.5" Front leveling lift kit for 06-25 Dodge Ram 1500 4WD.
No, stock tires. They’re 33.19” which is plenty big enough for me. The 3.92 gears are perfectly suited for this size tire when I’m towing.
I tow my bass boat and when it’s hooked to the truck, I do not want the rear lower than the front and I don’t want to mess with airbags. I like a slight rake, just not 3” which was how it was stock.
Do you have a full side profile photo? Interested to see how this turned out compared to stock visually. Looking to maybe trade up to the new Rebel myself.
So you installed 2.5" MotoFab spacers and the Mopar UCAs that come with factory leveling kit? I've got 2" MotoFab spacers and the Mopar UCAs on the work bench waiting for better weather to arrive.
