2025 ram 1500 no tow package.
Grimlakin
My wife got.me a light to go in the tow bar receptical thats supposed to light up like a brake light. But it is not working. Yes i plugged it into the lower receptical. But it was late at night so just posting here to make sure it's not some setting i missed.
Should work, you may have to trouble shoot several factors to find what is wrong. Does the new light work on another vehicle? Does a different trailer with lights work when plugged in? Etc. they also make tester plugs that you plug in to see if the lights are working or could be a fuse.
Someone in another forum said they were having trouble with LED trailer lights vs non LED lights.
Also check the wire harness connection behind the bumper to your 7 pin. Someone noted Ram removed some clips and the plug can wiggle loose.
Thought i replied here. Yes it works in another plug on a different vehicle. Waiting on my dealership to have a loaner before I bring it in. Got my truck from an hour away from my place. No dealership around me is willing to just check a few things quick like to see if it needs to be brought in for work.
That is a bummer and inconvenient. I know the feeling. Our dealer is just across town but when you work the same hours the dealer is open and work inside a plant. It becomes inconvenient to get it there. Means early drop off, catching a ride home and being brought back to pick up. Maybe they will figure it out.
Read this thread below discussing lighbar issues. On 2025, you will encounter trailer warnings. The lightbar should still work, though.
Checking with a closer clay cooley ram dealer to see if they can help me out for a loaner. Fingers crossed.
Ok I am told it's because the device my wife got me is a simple LED light on a circuit and it doesn't apply enough electrical load/resistance for the truck to know there is a light plugged in so it isn't activating. Their tester came back fine.
