2025 Limited Front 3x5 Speaker Wire Converter
Skater
Tejas
I purchased a set of Infinity 307F 3x5 speakers for my 2025 Limited, specifically to replace the corner front dash speakers. When I removed the OEM speakers, I discovered the plug shown below. Does anyone know where I can find a converter from that plug to POS and NEG for the speakers? The Metra 72-7902 Speaker Harness did the job for me on my 2020 Limited, but this new 2025 has a whole new wire harness setup for these front speakers, and I cannot find a compatible plug.
Thanks.
AFAIK, you will need a speaker that has 2 sets of connectors. The stock speaker gets 2 different signals from the amp. The headliner speakers use 1 set, but still use the same 4 pin plug. Inner pins are open.
Thanks for the response. The OEM speaker only has two connectors and two wires from the plug, so I'm not sure how having two sets of connectors on the speaker will help, but I know nothing about sound wiring. I will do some research on your answer and look into it. I appreciate your response.
i think i would leave the stock speaker in. the hk system has to sound good it's brand new.
