2025 Interior Fuse Box Layout
70runner
SOCAL
Was chasing an electrical gremlin in my 2025 RebelX using the pre-2025 interior fuse box layout floating around this forum provided by Hal9001. There is an "Interior Power Distribution Center" section in the owners manual (pg 323) that details access to the fuse box and provides a fuse list by cavity number. I recommend removing the metal plate (4 screws) that sits underneath the cover panel for better access. For those that have been down this road, I don't need to mention how difficult it is to identify the fuse cavity numbers. Used my phone to take magnified images of the box and was able to identify all 66 cavity locations.
The cavity locations are consistent with the Hal9001 image, however, there are many changes in the 2025 fuse layout. It appears the box itself is physically the same as pre-2025. The truck year, model, options, and such will determine the fuse vs cavity layout. The 2025s should be similar to mine, plus/minus fuses based on model/options. Attached pdf lists the 2025 fuses with cavity location and circuit description including the image below showing the 66 cavity number locations. The pdf also has the pre-2025 fuse/circuit information by cavity number. If anyone finds errors in the image/pdf, pls let me know and I'll update.
