Joeyarsenault92
- Oct 1, 2024
Hey all just wanted to share a bit of info and pictures of the newest mopar 2 inch lift with part number ending with a E, I am in canada the lift from the dealer cost about 3400 dollars (not cheap!) And when measuring the shocks and the rings that go on each front shocks everything measured the same as the latest version of this lift so I am not sure what the new lift with PN ending E is different but it seems all detention are the same, got the lift installed on a stock 2024 ram and the dealer put on 275/65/20 winter tires for me on stock rims, when they lowered the truck on the ground after installing the lift one of the rear shocks busted (oil came out around the shaft seal) and it took 2 weeks for a new shock to come in, warranty covered this of course, I have lots of pics with the lift installed and the last few pics is when I took off the front air dam and the splash guard under the front bumber, I think I'm going to out the air dam back on but I am.going to trim the splash guard a but lower, I discovered some.measurements and I have exactly 1 inch of rake and I'm.happy with the look it's barely noticeable but I am installed some 1/2 spacers to being it up just a tad more, I.got to say the ride is amazing, before I found the truck way too soft it would dip and kinda bounce when hitting a bump.on the road and not it has a stiffer feel and rides much much better, next is some red tow hooks I got off Amazon, if anyone has any questions just ask and I'll see what i can answer!!
