2024 1500 tradesman no retained power when engine off before door open anyone else?
ettodd
just got a 2024 tradesman 5.0 radio when i cut the ignition off everything goes off.all my other rams the power stayed on for 5 minutes or until you opened the door.are all rams supposed to have it?no door chime either.
The radio going off is usually adjustable in the setting somewhere. I usually set mine to time off after 5 minutes if the door isn't opened.
Found it.didn't scroll down enough to engine off settings.it was set on 0.had to download the specfic 5.0 radio users guide.the owners manual that came with the truck is about 1/8 the size they used to be.
