The issue started happening in the last week. In the settings, I have the display set for Manual and on 10 for both options (when headlights are on and when headlights are off). I like the bright display. I usually keep the headlights on the Auto setting. The other day, during the daylight, I drove under an underpass. The sensor in the dash picked up the change in lighting and flipped on my headlights....at the same time, the display on the radio unit and the dash went almost completely dark making it very difficult to see it. After investigation, now whenever the headlights are either set to "On" or when set to "Auto" at night and the headlights come on...the dash and display go dim and are hard to see. The only way to correct it is to dial the dimmer switch all the way up. It seems like if the headlights are engaged, it is now automatically dimming the dash and display to a very low level...any ideas?
