2021 Ram Rebel Air Suspension Delete
harcam
Forgive me because im sure this has been asked 1000 times but i can't find a straight answer.
Air suspension went out and i want to install shocks/coils. I would like to put a 2 or 3 inch lift on it. I don't tow often and never have a heavy payload. I want the truck to be level and maybe put some bigger wheels on it at another time.
My question is, what kit is best for the Rebel (quality wise), do i need to replace the upper control arms? i really don't want to do modifications.
Thank You for your time.
G
Look at Bilstein 5100's or Eibach, lower budget would be Rough Country. I would recommend swapping UCAs
Depending kit, you will need to buy new strut mounts. Some online places will assemble struts and sell as a kit for Bilstein.
I found airdelete on line with the Bilstein package that looks complete. I just want to make sure my truck will sit level and not bounce going down the highway. Then i need to figure out had to remove the air ride from the BCM so the light does not stay on in cluster.
I believe AlphaOBD, Security bypass and OBD scanner will work, maybe someone can confirm
check here also
Another
