2021 Ram 1500 not starting
scavallaro85
I have a 2021 Ram 1500 that wont start. Hit start button and i get a bunch or messages saying active tuned mass module temporarily unavailable, service electronic stability control, service antilock brake system andspeed control messaging unavailable servicing required. It doesnt even attempt to turn over. PLease help
scavallaro85
I should also mention i have a diablo sport tuner which ive called them and they state its unrelated. This happened christmas eve where it was 18 degress out and its 18 degrees out now. last time it started working on its own a few hours later not sure why.
jl13
boyle heights, CA
could be your battery, have seen several threads and sometimes a bad battery seems to be the issue.
mine was done at 1 year and 3 months. It didn't do anything crazy like others have reported, it just went completely completely death
scavallaro85
ive even put a jumper on it and no change
Scram1500
Should still be under warranty, however life would be easier if you replaced it yourself with a higher quality battery. You could also go bigger with an H8 for more reserve and better cold cranking
scavallaro85
Do you think it could still be battery related even with not even the slightest attempt to turn over yet my lights and everything else come on full strength?
Scram1500
The battery would need to be load tested to confirm if it was toast. Did you test the battery voltage?
scavallaro85
I did not as i do not have access to anythig where i am stuck. I tried a charge station with a jump feature and a nocco jump start with no luck or change.
