2021 Longhorn Harsh Ride - Not level
Markcon371
New York
Hello all.
Recently put larger tires on my 2021 1500 Limited Longhorn, and revel links all around for lifting.
First issue, truck is uneven, as you can see in my ride measurements in the note picture, taken in normal height.
Truck is riding very rough. I’d like to put stock links back on, just tried to but with cold plastic and nothing to “lubricate” the plastic on the stock links, I couldn’t for the life of me get them to snap back onto the ball either end, and I was nervous I was going to break the height sensor arm.
Second issue I see in my JScan screen shots is rear shocks are equal in PSI, front left is almost 15 psi more than front right, but is still sitting lower.
Any help is appreciated, and if anyone has any tricks to getting the stock links back on without breaking stuff, please tell me
I see this is an old post, so hopefully you've solved the problem. But based on the ride height sensor readings it seems like the front links must be set to different lengths. Did you check that?
Also, can you change the ride height position with jscan like you can with alphaOBD?
