2020 Ram leaking
T-dizzle
I have a 2020 Tam 1500 with the 5.7 and was curious if anyone has had any issues with fluid leaking. Not quite sure what the fluid is but it is clear but it stains the driveway. Wouldn’t this be covered under the drivetrain warranty?
It is definitely covered under the basic warranty (unless you're already over 36K miles then the powertrain should cover it depending on what the cause is).
Snap some pictures of the issue to show the Service Advisor when you take it in. Rather than giving them the truck and telling them "it leaks", narrowing down the search for them they are more likely to find the issue rather than give you the truck back and telling you they can't reproduce your concern.
