I'm going to installed a hood LED strip I got off Amazon and it has the option to include turn signals indication.
I've looked and cannot see any way to access the headlights wiring harness(es) to T-tap the turn signal wires.
I can see what I believe to be the connector on the driver's side by partially removing the fender well liner but no feasible way to disconnect the connector or access the wiring to T-tap it.
Assuming others have added similar accessory and crossed this bridge before.
I'm considering just connecting to the trailer turn signal wiring and run the length of the truck. I did a test run just running a2 conductor to back of the truck and sticking the wires in the 4-wire flat connection and it worked without any errors.
Just thought if there's an easier way than running wiring the length of the truck that'd be preferred; but I also don't want to risk breaking a hard to get to connector up front.
