2020 Ram 3500 blind spot delete.
BighornLVL2
My new work truck is being setup as we speak. It is a bighorn 3500 with the level 2 group. The box will be removed and replaced with a service body. Question is, will Alfa OBD with a bypass module work to disable the blind spot system. If yes, what would be the steps to disable. I’ve seen the Alfa OBD will work on the older models to disable, curious if anyone has tried on a 2020 3500 model. Is there a bypass module that does require the removal of the gauge cluster? Thanks
