2020 Ram 1500 Bighorn AlfaOBD mods.
Warrior5delta
Proably beating a deadhorse here, But has anyone successfully been able to make any mods work? I have most current version of alfaobd, sgw by pass cable, abd OBDlinK MX+
I tired the auto high beams, show in ipc settings, but does not work. I do have the correct review mirror, I have the rain sensor, but keeps throwing message stating its lose connections to sensor. also in IPC settings. Tried dozens of times for Global down with remote, no go. The only things that have worked so far is the foglight drop out with high beams, Heated steering wheel and seat heat level.
I am using alfaobd on a motorola moto g stylus, Android 13
Was hoping to make changes to IPC.
thanks in advance for your feed back.
I have successfully done everything you mentioned, except global windows. That is known to not be possible on these trucks. When you say you have the rain sensor, are you referring to the one that came with the truck or did you replace it? Did you swap your mirror too? Both needed to be swapped and then programmed in alfa.
Thanks for the reply. I have the required rain sensor and mirror based on what I have read in the forums.
Do for the auto high beam you said it shows in the ipc settings, so it must be programmed. When you are testing it, do you have the turn signal lever pushed to the forward position. If not they won’t turn on automatically. For the rain sensor are you using 68298334? And you have it turned on in the menu on the radio?
I was able to activate the tail gate ajar warning. My door sticker said it was there but it was not visible.
Sorry to be posting on this older thread but hopefully someone can answer my question or steer me in the right direction.
I already have the proper light switch with "auto" setting in my 2019 RAM 1500 Bighorn and will purchase the correct mirror (with forward "Sensor") to be able to add the auto highbeam feature to my vehicle but what are the step by step procedures using AlfaOBD to program my truck to recognize this feature and enable it?
Thank you
