2020 Laramie 1500 4x4
Sarge48
Will the 295/70/ 18’s or the 275/70/18 with a 2 in level kit ,which will have the better look? Any pics would be appreciated. Also if I go with the 295’s would the upper control arm need to be different?
Looks good is that with the 2in level and any upper arm control issues?
295/70/18’s are heavy, you would notice a significant difference in performance as well as MPG with the 295/70’s. Even on my 2500 diesel the performance loss was obvious, its gotta be even worse on the 1500.
No UCA issues yet. Mpg did go down a bit but that’s the trade off with heavier wheels and tires. It rubs on certain driveways\dips but nothing major that you need to trim
I recently put these wheels and tires are toyo at3 295/75r18
and did you put 2 in level on it or not?
Did it make your ride better worse or same?
Thanks for your time trying to decide. Really don’t want any rubbing acct I off road some (hunt)some say with a 2 level they don’t rub??
