2020 Headlight flicker
FergusonBellows
Toronto, Ontario
Just picked up a 2020 1500 Sport Crew Cab (Canadian trim level), I have 300 kms on the truck. When I start it up the left headlight will flicker, then maybe the right side. If I turn a corner they might flicker as well. I thought my eyes were playing a joke on me. Anyone else experience this issues?
Are you sure it’s not the fog lights turning on? If you turn the wheel far enough they will come on.
Correct. I experienced the same flicker and then realized the fog light on the side you are making the turn will turn on. What I thought was an issue, is actually a really nice feature. It's probably in the user's manual, but who reads it???
its not a flicker the fog lights are used as a cornering light if you have your fogs on when your headlights are on the feature does not work, if they are off the feature works.
I have a limited and the headlights will steer around turns. They go thru an alignment sequence (adjust themselves left and right) upon startup. Not sure which headlights you have, but it could be this.
I have a 2020 Sport trim as well. Your fog lights will turn on depending on what direction your wheel is facing. Just an added feature. It actually really helps as it brightens up the area....especially at sidewalks
When I bought mine, I enabled my fogs and saved this to memory. I like the extra light thrown around the nose of the truck. So I’ve never even used this feature!
Thanks for the information, very random feature, thought I would have caught this during all the reviews a watched and read.
