Intermittent problem, happened 4 times in last 3 months; three times in June and once last week. On entering truck brake pedal will not depress, push button will go to acc and starter does not engage. Apply and release Park brake, no change. Exit truck and try remote start only get loud click at starter. Battery good. No codes. After many attempts, anywhere from 10 to 100 minutes brake releases and truck starts fine. Dealer unable to duplicate but found loose connection on starter. Replaced starter and are 85% confident problem solved. I can't believe that a loose electrical connection on a starter could cause the brake pedal to lock. Could it be the immobilizer? Anyone experience this issue?
