2020 3500 Limited UC4 - UC5 upgrade Issues
timbo1083
Hello everyone. Through the very wonderful help of some members here I have a 2020 3500 Limited Dually with the 12" UC5 scree/module. I did the work to put a UC5 screen and radio module and everything is working minus the satellite radio (I did connect to new radio but I cannot get it to show up as an input option) but one thing I cannot figure out is the 360 camera display. I can select each camera individually but I cannot see the 360 view. Please see pic. I feel like this is a setting in Alpha somewhere. Any suggestions? IMG_2484.jpeg
Did you change your model year to 2022 in the Body Control Module using AlphaOBD?
You need to run the CVPM configuration procedures with something like AlfaOBD.
EDIT: @timbo1083
When you connect to the CVPM, go to Active Diagnostics and select the CVPM Service Calibration procedure. From there, select "enforced calibration" to calibrate all cameras. Keep in mind, some cameras may not calibrate on the first try.
For the calibration, find either a long stretch of road or a large parking lot. You will need to drive straight at 2-8mph so an area with low traffic and lots of room is important. You can also calibrate the cameras one at a time if room is more limited. I easily covered a 1/4 mile calibrating my cameras so keep that in mind. I found a parking lot with nice, crisp lines worked well for calibration. A well marked road should work just as well but those are usually busier than school parking lots on weekends.
