2020 1500 fuse layout
cjwrobel84
Hey all, I’ll try this here but I’m struggling.. truck ran fine last night, went to fire it up for work today.. completely dead.. used the emergency key to get in and alarm just blares… disconnected negative from the battery.. 30 minutes later… same issue.. fob batteries are new… I’m scratching my head with the fuses.. anyone have any insight, it would be greatly appreciated. Thank you!
Have you had any water leaks in your rear slider (or shark fin)? It might be your RF hub is toast.
But if you want to check fuses, you’re looking in the wrong place. Look at the internal power distribution center (the fuse block under your steering wheel). Fuse F24, maybe?
We did have a bad rain last night… I will check that fuse in the daytime.. thank you.. trying to avoid the dealership lol
